F4i Digital speedometer
The F4 to F4i gauge conversion/swap is possible w/ modifying & adapting your wiring & instrument panel. You can also do a complete F4i front conversion using the F4i fairing stay.
Searches for "F4 to F4i gauge swap/conversion" will get your started...
on
1 Post
Yes it can be used.. the electrical seems to be the easy part.. mounting options if you keep the F4 upper fairing means you have to make your own mounting setup...
I recently looked into the swap and I tried to centralize much of the info as I found it scattered all over the place.
the post is https://cbrforum.com/forum/cbr-600f4...thread-129237/
I ended up deciding not to do it since I wanted it to be 'plug and play' in case I wanted to swap back and the mounting I had in mind would not have made it cost effective for me... but they do look awesome..
What? Wait. When did this happen? I was looking forward to the definitive F4 to F4i gauge swap! Oh well.
