diff between F4 and F4i???
Old Aug 8, 2006 | 02:02 AM
spdrmns's Avatar
Default diff between F4 and F4i???
hey guys i am wondering what the main differance is between the F4 motor and the F4i motor other then the fact that its fuel injection if there is another difference...
Old Aug 8, 2006 | 04:16 AM
dwhite645's Avatar
Default RE: diff between F4 and F4i???
I believe the heads are entirely different.
Old Aug 8, 2006 | 11:05 AM
city worker's Avatar
Theirs an "i" in the name, ha ha sorry could'nt help my self
Old Aug 8, 2006 | 04:29 PM
dragonium25's Avatar
The F4i is fuel Injected, the F4 is carburated.
Old Aug 8, 2006 | 05:46 PM
DThompson's Avatar
ORIGINAL: dragonium25
That is correct, Thats why they put the ( I ) in the name. Its also called the F4-2 in the auto manual because its the second version of the F4
Old Aug 8, 2006 | 08:26 PM
spdrmns's Avatar
you guys were a HUGE help. you guys obviosly didn't read the question did you?? hahaha.. ((((OTHER THEN THE FACT THAT ITS FUEL IN-JECTED)))!!!! YES I KNOW THE F4i IS FUEL INJECTED! AND THE F4 IS CARBED! wow..
Old Aug 8, 2006 | 09:44 PM
woot's Avatar
Hey - I'm a F4 rider myself... the Clymer is common between the F4 and F4i.
Most parts seem the same. Body work has been swapped between the two, the frame, rims and lower part of the engine look the same...
The tank might have few differences, the wiring is significantly different... [g 537-538 list differences in the wiring of the regulator...
Page 539-540 the iginition system is different (f4 has a 10a fuse, the f4i has a 20a fuse) The f4i also has a tip over kill switch...
Starting system looks common.
Not going to go through the wiring diagram... but a few differences on the dash. 20km/h indicator for f4... must be for the way the fuel is handled? There is a FI test light for the f4i.
I'll stop there... but as far as I can tell. Tweaked body work, maybe modified suspension but I didn't see it, fuel injection, and the required electrical changes to make that work.
Skibum
May 20, 2011 07:06 AM
snowboarding82
Aug 21, 2006 06:46 PM
lang1864
May 18, 2006 11:42 AM
CivicRacerX7
Feb 14, 2005 11:33 PM
