Coolant leak (fixed maybe)
Old Jul 11, 2011 | 11:51 AM
Kuroshio's Avatar
Default Coolant leak (fixed maybe)
Already solved it (I think) but I figured I'd let y'all know what happened and what I found.
I was supposed to meet a friend for dinner. The restaurant is on South St here in Philly, a popular party / be seen street. So I figured I'd ride there and... well, be seen . Yesterday, however had to be in the 90s. And I, quite stupidly, decided to ride down all 38 blocks of South St instead of taking I-95 and riding a couple blocks to the restaurant. So approximately 30 blocks of < 20 mph riding, with the last 14 blocks < 10 mph.... in my gear too. Bike hit 233 degrees by the time I got to the restaurant (maybe 10 degrees hotter than me in my jacket).
When I got to the restaurant, my buddy was waiting out front. And the first thing he said is "You're leaking coolant". Sure enough, a pretty good stream of coolant spilling out as I parked. Since I didn't go above 233 degrees (and was in dire need of a beer), I wasn't significantly worried. I checked the reserve bottle, saw there was coolant in there and went inside for the beer (just 1 during the 1 1/2 hour dinner). Came out, rode home (taking I-95 this time instead of going local). Ride home, never got above 220 with 185 at freeway speeds.
This morning I go out to see what I can find. And this is what I find
If you look closely, the coolant siphon hose is barely on the radiator. The lock ring is definitely not over the hump that's supposed to lock down the hose. I figure as the temp climbed, the pressure forced coolant out the hose around the nozzle. Without a good seal instead of maintaining a vacuum, it became a path of least resistance for the coolant.
Gonna get a better locking ring (I hate those pinch type), top off the radiator / reserve and burp the system to make sure there's no air in it. See what happens from there
Old Jul 11, 2011 | 05:41 PM
MadHattr059's Avatar
With any luck, you didn't lose more than your coolant reserve had. That'd even save
you a burb. ;-) Personally, I prefer the screw-band clamps for everything. More secure
and generally easier to manipulate. Hope it all works out...*fingers crossed for you*....
By the way, thought occured to me, there shouldn't be any pressure on that line. If it's the over-flow to the reservoir, it should basically be atmosperic (+/- for the siphon effect). If it was "pushing' on it, ther may be a blockage or kink. Something to think about, if I'm reading it right. ;-)
Ern
Old Jul 11, 2011 | 11:44 PM
Kuroshio's Avatar
Shouldn't be any kinks in the hoses. Haven't been under the fairings since... never
You gonna make me flush the radiator aren't you?
stewyF4i
Apr 17, 2014 10:56 PM
Ragnar1x
Apr 9, 2011 09:29 PM
Fast RR
Mar 29, 2009 10:35 AM
SReeD08
Apr 20, 2008 12:47 PM
mattyg
Apr 26, 2007 02:58 PM
