Clutch slipping again
Old Jun 21, 2020 | 07:52 AM
Daz Tank's Avatar
Default Clutch slipping again
I replaced clutch and clutch cable about two months ago. All was good. About a week ago my bike started to just pop outta first gear under heavy acceleration. Has done it three times now. Tonight the clutch has started to slip around 8000rpm. I adjusted it at the lever end, still slipped. So I adjusted it at the lower end, took it for a ride and it's slipping worse than earlier. Any reason why I've burnt thru a clutch so quickly? I haven't been doin any wheelies or clutch dumps
Old Jun 22, 2020 | 09:50 PM
SunBlue's Avatar
ru using an aftermarket clutch pack? sometimes theyr not quite the correct stack height and end up burning.
in either case u need to open her up and check whats going on inside
Old Jun 22, 2020 | 10:33 PM
Daz Tank's Avatar
Default Thanks for your reply
It's weird, when the bike is under heavy acceleration, around the 6000rpm mark the clutch slips a lil and then just slingshots
Old Jun 23, 2020 | 01:17 PM
chris0986's Avatar
I'm with SunBlue.
Also if you're looking at doing the job again, are you in posession of a workshop manual like a Haynes manual?
It tells all the details how to exactly tune a clutch. It can make a huge difference...
Another thing could be the oil you're using, however I assume you don't use something extraordinary for this bike?
eljrc16
Dec 13, 2008 06:36 PM
itgbudeev
Sep 5, 2008 11:47 AM
chrislemd
Aug 30, 2008 07:38 AM
A4wheelin
Jul 24, 2007 08:33 PM
pixel 6
Oct 4, 2006 05:47 AM
