Clutch Problem...I think
Old Mar 27, 2006 | 09:12 PM
ryanoxj's Avatar
Default Clutch Problem...I think
I got a F4i and it will run only while the clutch is in, once i let the clutch out the bike goes dead. I have bypassed the clutch switch and the kickstand switch and no luck. anyone have any ideas??
Old Mar 28, 2006 | 12:17 AM
thunder31634's Avatar
Default RE: Clutch Problem...I think
in gear or in neutral or it doesnt matter??
Old Mar 28, 2006 | 12:29 AM
ryanoxj's Avatar
it doesnt matter what it is in it will go dead when its in neutral and when i try to drive it no matter how much gas I give it. I have asked everyone i know and they have no clue. It doesnt make any sense.
Old Mar 28, 2006 | 01:07 AM
shraz's Avatar
even with some throttle?
Old Mar 28, 2006 | 02:12 AM
jiveturky's Avatar
yeah its crazy, i got a friend looking at it who was a bike mechanic for 7 years and he is at a loss for words, and he called someone who worked at a honda dealership for a few years and he has no idea. He took the clutch case off and is going to try another one since it has a sensor in there and see if that works if not going to take the clutch apart and see if maybe something is wrong there.
Old Mar 28, 2006 | 02:16 AM
ryanoxj's Avatar
the post earlier was mine just noticed that it was logged in under a friend. thanks
Old Mar 30, 2006 | 11:22 PM
as bad as this sounds the only thing i can think of is the "input" side of your tranny is in a bind (locked up) you can check this by putting it in gear w/engine off and clutch in, and try to push the bike if it wont move then its a tranny problem, if it does....... im lost!
hope that helps
james
Old Mar 31, 2006 | 01:17 AM
ryanoxj's Avatar
I am pretty sure that i moved it while in gear with the clutch in but i will check that tomorrow. thanks james
Old Mar 31, 2006 | 10:58 PM
ryanoxj's Avatar
Dont know how or why but it works now.??????????? I thinking that something might have gotten wet some how and needed to dry out. But i got off work today and put the clutch case back on, it was off because i had a friend(bike mechanic) looking at it, and it started right up. I just stood there dumbfounded. A week of pulling my hair for nothing. I am pumped.
thanks for all the replies.
mlrtime99
Oct 10, 2007 03:11 PM
smak_blaze
Mar 30, 2007 05:40 PM
lowrinlife
Jul 30, 2006 02:18 PM
lowrinlife
May 27, 2006 12:18 PM
lowrinlife
May 26, 2006 09:21 PM
