Clutch cover install trick???????3rd broken pin..
Old Sep 24, 2018 | 06:38 AM
Venus974's Avatar
Default Clutch cover install trick???????3rd broken pin..
A broken 3 clutch pins trying to get the clutch cover on right what am I doing wrong
Old Sep 24, 2018 | 10:42 AM
tentacleslap's Avatar
Do you mean the alignment pins? They should fit easily by hand. If you're tightening against them under tension, something has gone wrong
1) Remove all pins. Fit clutch cover by hand and ensure it sits flush against the crankcase. If it doesn't, you should redo the clutch job paying careful attention to the manual
2) Reinstall pins. Fit clutch cover by hand and ensure it sits flush against the crankcase. Don't install the bolts until it does. You might need to go in with a pick and scrape out the holes where the pins go
Old Sep 26, 2018 | 01:45 PM
Venus974's Avatar
o me I mean the the clutch pin that attaches to the clutch cable and I get it all flushed and then as soon as I pull the clutch in it breaks
Old Sep 26, 2018 | 05:48 PM
Nobody likes rework, but she's a great teacher
I'd go back and check your work. Confirm installation and adjustment
dougcrx
Jan 18, 2012 04:26 PM
benjiboy
May 27, 2008 11:44 PM
BillytheKid
Sep 27, 2006 01:40 AM
kylesbored
Aug 1, 2006 07:03 AM
lowrinlife
Jul 30, 2006 02:18 PM
