Charging System Problem
Ok so I charged the bike over night. Fired it up took it for a 25 miles cruise, came home turn it off, and then out of curiosity I tried to turn it back on, very weak starter sounds couldnt get it to fire up.
The battery holds a charge
Ok heres my specs on the system today
Sitting after charge 12.4
Running 13.4 - It was charging, and then shut the bike off. Then fired it back up and it didnt charge(check charging system)
When I rev it up it doesnt really move on volts it sits around 12.9-13.4
Ok I checked the wires for the R/R came out 12.4 sitting same as battery
I checked the Alternator wire came out to be 0.5-0.7 was bouncing back and forth between those numbers.
What else is there to check if the R/R and alternator/stator check out ok whats next a short somewhere or battery ?????
