changed oil... now no oil pressure
Old 07-09-2006, 09:08 PM
Jaycbrf2's Avatar
Default changed oil... now no oil pressure
Hi everyone, need some help. I just changed my oil on my 94 f2. Used honda oil and filter. Started it up and oil light didnt go out. I let it run for about 20 seconds thinkin the pump had to prime but the engine just got noisier. dont want to sieze the motor... anyone have any suggetions. thanks
Old 07-09-2006, 11:23 PM
Default RE: changed oil... now no oil pressure
I usually fill the oil filter with fresh oil before I screw it on. I dunno, maybe it's a no brainer like you didn't screw the filter on enough and it's leaking or you left the plug out....not meaning to insult you or anything, but I've seen all sorts of things that make you go "DUH".
Old 07-09-2006, 11:53 PM
MAKE SURE TO CHECK YOUR OIL LEVEL IT MAY JUST NEED TO BE TOPPED OFF, ALSO IF YOU HAVE A DIPSTICK AS AN OIL LEVEL CHECK DO NOT SCREW IT IN JUST PLACE IT ON TOP OF THE FILLER HOLE AND CHECK WITH THE BIKE LEVEL.
Old 07-10-2006, 02:37 AM
yeah pull the oil filter and see if there is any oil in the filter. if not fill it up and try it again.i allways run Lucas oil additive in mine so there is no dry starts.
Old 07-10-2006, 02:43 PM
Jaycbrf2's Avatar
Thanks everyone. I pulled the filter and it was bone dry. cranked the engine and had no pressure. I was running out of ideas so i put the bike in gear, pulled in the clutch and rolled it forward alittle bit and then cranked it and had oil pressure! dont know what would cause this... maybe oil pumps on the way out. Thanks for help.
supersnake83
07-05-2009 01:56 AM
camaro_forums
07-24-2008 10:51 AM
clay1219
01-21-2008 09:11 PM
brancart1
07-10-2006 11:14 PM
Quick Reply: changed oil... now no oil pressure
