changed oil... now no oil pressure
Hi everyone, need some help. I just changed my oil on my 94 f2. Used honda oil and filter. Started it up and oil light didnt go out. I let it run for about 20 seconds thinkin the pump had to prime but the engine just got noisier. dont want to sieze the motor... anyone have any suggetions. thanks
RE: changed oil... now no oil pressure
I usually fill the oil filter with fresh oil before I screw it on. I dunno, maybe it's a no brainer like you didn't screw the filter on enough and it's leaking or you left the plug out....not meaning to insult you or anything, but I've seen all sorts of things that make you go "DUH".
Thanks everyone. I pulled the filter and it was bone dry. cranked the engine and had no pressure. I was running out of ideas so i put the bike in gear, pulled in the clutch and rolled it forward alittle bit and then cranked it and had oil pressure! dont know what would cause this... maybe oil pumps on the way out. Thanks for help.
supersnake83
07-05-2009 01:56 AM
