chain question
Old Oct 28, 2007 | 05:21 PM
Nauree's Avatar
Default chain question
So, I havn't really cleaned, lubed, or adjusted the slack of my chain for about 3k miles. lol...I've been planing to get new sprockets and chain every since but never got around to doing it. Last night I noticed that when I started to take off, I would hear a sound that sounded like rocks hitting me. I decided that it was my chain. I checked it out today and it had so much slack, it was hitting my swing arm, 2+ inchs of slack. I'm cleaning it and lubing it now amd plan to find a shop thats open to replace them. My problem is the slack at the moment. On part of the chain theres a crap load of slack but when I check another section theres like no slack at all and its tight as hell. Do I adjust according to the section with the most or least slack?
Old Oct 28, 2007 | 07:33 PM
PowerTrip's Avatar
Default RE: chain question
You should check the slack in the chain about midway between the sprockets on the bottom portion of the chain. There really shouldn't be spots where slack is and other spots where it is tight if your feeling on the same side of the chain. If the bike is in gear the top part of the chain will feeltight but the bottom will be slack, hopefully that's what it is and not kinks in the chain.
Old Oct 28, 2007 | 07:41 PM
blackcbr's Avatar
dude u have what is called a tight spot(u have slack in one section and when u roll the rear wheel for half roll and check the same spot u find it so tight) that means that u need a new chain right away b4 it damages ur sprocket . it happens usualy when u dont take of ur chain (lubing-adjusting- cleaning) which u mentioned that u hadnt done it for 3k (crazy) .o get a new chain ,,
Old Oct 28, 2007 | 08:02 PM
NY Erion929's Avatar
ORIGINAL: PowerTrip
+ 1
Chreck your manual for the actual distance, then measure it like this
You should have about 15-20mm of slack up and down.
Old Oct 28, 2007 | 08:04 PM
Nauree's Avatar
just using my chain to the fullest.
Old Oct 28, 2007 | 08:07 PM
ORIGINAL: Nauree
Untill it snaps, rips open your leg then smashes your undertail [8D]
Old Oct 29, 2007 | 01:14 PM
blackcbr's Avatar
ORIGINAL: NYErion929
ORIGINAL: PowerTrip
+ 1
from what he said that he apparnetly checked it at right .. but he said that the slack changes at the same spot from 2 inches to no slack at all (tight) and that means that the chain is strertched out at some part and some part are not .. and that could damage the sprockets.. .. just my .02
killab213
Mar 20, 2010 01:59 PM
Perranomous
Apr 19, 2009 03:04 AM
simtech
Jul 7, 2007 12:16 AM
richhowerton
Jun 13, 2007 08:04 AM
dlbinford
May 19, 2005 09:14 AM
