chain lube
Old Jan 31, 2007 | 07:33 AM
2wheelpirut's Avatar
Default chain lube
hey all,
i have a 3-month old F4i. how often should i lube the chain? what should i lube it with? some fancy expensive fluid that comes in a nice looking can? good ol' grease? gear oil?
how often? apart from saturday morning 3-4 hour rides, i pretty much stick to commuting on the bike.
one more thing: honda says chain play should be between 1 and 1.5 inch, but i ALWAYS feel like the chain is too loose. should i be bothered?
thanx for the input i know will come, guys. thanx so much.
Old Jan 31, 2007 | 09:52 AM
doncollins's Avatar
Retired Administrator
Default RE: chain lube
I always keep my chain to about .5 to 1 inch slack, use chain wax instaed of lube because it doesn't make as big of a mess and "I believe" it stays on better. The recommended mileage is about every 200 / 300 miles. I ride that in a day most of the times so I check mine out on the weekends and average about 500 miles or so. I don't take my chain off and clean it like I should, I just use a cleaner or WD 40 and brush it while it's on the bike. Seems to work ok for me.
Old Jan 31, 2007 | 10:45 AM
knightslugger's Avatar
If it looks dirty, clean it. not everything is safe to use as a cleaner though. do a search to learn more. otherwise, there is no such thing as chain wax in the literal sense. there are lubricants that leave a waxy residue when set up, which is where they get their name from. Maxima makes a brand of lubricant called Chain Wax. it comes out of an aerosol can in a pretty liquid form. after it evaporates, what is left is very tacky substance that resembles wax.
I clean my chain when ever it looks dirty. i use a soft bristle brush and Honda Pro Brake and Contact Cleaner to clean the chain the chain. after words i use Honda Pro Chain Lubricant w/ White Graphite sparingly. i clean up any excess and i walk away.
Old Jan 31, 2007 | 11:38 AM
abadfish's Avatar
ORIGINAL: 2wheelpirut
hey all,
I still need to add some pics but:
http://cbrworld.net/forums/thread/258433.aspx
Naruku
Sep 11, 2009 06:14 PM
repyosol
Oct 29, 2008 08:29 AM
Cun0144
Sep 5, 2008 11:24 AM
CRAZY_600RR
Jul 17, 2006 07:00 PM
