CBR F2 issues
Old May 22, 2012 | 09:45 PM
hondamech86's Avatar
New Member
Default CBR F2 issues
I have a 91 cbr 600 f2 it wont start ive bought new spark plugs so i know its not that ive had the carbs done and they are pumping fuel but it still wont fire up so im kind of stuck not to sure wat it could be. Any advice is welcomed im not to experienced with carbs.
Old May 24, 2012 | 10:02 AM
adrenalnjunky's Avatar
Firing order correct? 1-2-4-3 Also 1&4 should be off the right side coil, 2&3 off the left.
Also - you got new plugs, but are you getting spark? Pull them out and check for spark at the electrodes.
Engines are just fuel/air/compression - combine them in the proper order and it should run.
Old May 24, 2012 | 08:25 PM
Optimus_Prime's Avatar
As mentioned already, spark and compression are worth a check and are pretty easy to do. Removing a plug, reconnecting it to the plug lead and grounding it to the engine block should show a spark if you try and start the engine. If you can get hold of a compression guage then knowing you have good compression can rule out that problem.
Has the bike run recently or been sat for a while? Is the fuel fresh? I just helped a friend get a scooter going and all it took was fresh fuel because it had been sat for a year.
mooseboy
May 21, 2011 03:11 PM
ddavis17
May 21, 2011 11:51 AM
SparkeeVR4F4i
May 13, 2011 04:06 PM
mk4
Apr 3, 2011 12:22 AM
05CBR600F4i
Feb 6, 2011 08:40 PM
