CBR 600 F3 Quad project.
#21
Cool Cool thanks, now im just waiting for the rectifier to come in the mail. be ablout a week sadly, so untill then im gonna stretch the swing arm a couple of inches, and fab up a nerf bar system to keep my feet from the wheels haha.
as it sits no, the pedal assembly sits alongside the tire, one slip and my foots in alot of trouble.
#22
I'd mount some floor boards and at least some expanded metal for fenders on the
rear. Using the kick-stand switch for an over-board kill, occured to me as well, but
some-one already mentioned that. And I think you have to wire the guages for the cdi
to start the fuel-pump. It came up in another post, where the dude was using an F3
engine for a circle-tracker.
Ern
Ern
#23
#24
#25
#26
#28
im about 2 weeks behind you in my build... only difference is mine is going in a lawnmower. from what i have read/ learned you shouldnt need a regulator to start it. i could be wrong tho. what you will need is a gauge pod. by the looks of things the gauges control the air solenoid and that makes a huge difference in performance.
i too am waiting on a regulator and also a cdi and coil. we plan to also eliminated all of the wiring harness that we arent using... which is basically the lights
#29
Thats pretty cool looking, im going for all 4 wheels, i thought about 3 but ive had bad luck with 3 wheelers.
Mower sounds pretty bad ***, just make sure you can still hold onto a beer while driving it.
So i put on the regulator, charged the battery, hit the button and...... Click,Click,Click,Click,Click,Click, the relay right off the positive side of the battery with the 30 amp fuse goes nuts, idk if it died in the cold weather while i was gone, or what, but it doesnt crank over at all now. i didnt think about disconnecting the regulator when i was out there, but i will tom when i go back out.
any ideas?
any ideas?
