CBR 600 F2 starting problems
Old 10-06-2011, 03:01 PM
tomtom's Avatar
Default CBR 600 F2 starting problems
Hi my CBR is playing up. it starts most of the time but sometimes it dosent start off the button and i have to bump it to make it start. i was wondering if anyone else has had this problem or if anyone knows how i could fix it
thanks howard
Old 10-06-2011, 05:48 PM
MadHattr059's Avatar
First step, pull the battery and have it tested at the local auto store. For free.
If battery tests good, check the starter relay. if it tests good, check to see if the
starter is good. While you're in there check the connector for the R/R (on the right side
of the bike). Look for heat-sign. i.e. melting, burnt, warping of the plastic.
Those are the probable spots. You might also inspect the switch, itself. It could, also,
be the point of failure.
Hope this helps, Ern
Old 10-07-2011, 10:26 AM
tomtom's Avatar
Hi, when i go to the bike it starts maybe 9 out of 10 times, its an intermitant problem and i wonder if anybody has had this happen to them before?! i have noticed a little light to the right and down from the clocks and wonder if the bike has had a factory fitted alarm.
The light dosent come on at all. cheers Howard
Scorpio_13
01-15-2018 09:50 AM
kpnupe
08-09-2009 11:33 PM
99offroadrngr
07-31-2008 12:10 PM
deisback
08-28-2007 01:11 PM
snobrdrdan
06-01-2006 01:23 PM
Quick Reply: CBR 600 F2 starting problems
