causes of speed wobble??
Old Sep 25, 2011 | 03:51 AM
itlnF4I's Avatar
Default causes of speed wobble??
tonight i got it 3 or 4 times, never had this issue before so i know it wasnt just the front wheel coming up in 2nd. its only at high speeds. i took it out for the first time since i came down super hard from a standup and put a hole in the radiator, so im going to assume i damaged just one fork, but it doesnt seem akward handeling. any input??
Old Sep 25, 2011 | 09:03 AM
RoadiJeff's Avatar
Senior Member & Lord of The Man Cave
My old bike had a high speed front end wobble that was caused by the REAR tire being way out of balance.
Old Sep 25, 2011 | 03:20 PM
itlnF4I's Avatar
forgot about the rear until you mentioned it, i did let the pressure down to 25psi to practice standups, could that cause it?
Old Sep 25, 2011 | 05:58 PM
Ls1Tuner_06's Avatar
^^^i say try that first. At least this way you can start ruling out problems if this doesn't help
Old Sep 26, 2011 | 04:16 AM
itlnF4I's Avatar
haha, they are all good roads though. florida takes care of their highways. after i figure out where my short is in my radiator fan circuit ill put air in it and test it out.
Old Sep 30, 2011 | 07:14 AM
itlnF4I's Avatar
anyway, fixed the radiator fan, put air in the tire. seems to do it less, or maybe i compensate because i know its coming. but it just seems like the front end is barely on the ground at XXX speeds. i dont think having a naked bike would cause that much.
Old Oct 13, 2011 | 04:28 PM
mark1200's Avatar
loose or worn steering head ,and swingearm bearings are another comon cause. tire balance.
low rear tire psi should not be a cause. drag racers run low psi all the time.
Old Oct 14, 2011 | 05:08 AM
itlnF4I's Avatar
idk i put the tire pressure back up to 35 and it pretty much stopped. it just feels like the front end wants to come up at high speed. i know my head bearings are getting egg shaped from all my practicing on one wheel though. i have tapered bearings in my toolbox i just have to stop being lazy
Old Oct 15, 2011 | 09:49 AM
highwaypatrol's Avatar
Sounds like the head bearings need to be changed as soon as you can get around to it and 35psi for the rear tyre seems a bit too low. Mine runs on 42psi. The front has 36psi. Check with you handbook for correct pressures. Running on the wrong/low pressures could land you in casualty! lol!
itlnF4I
Oct 29, 2013 03:15 AM
subyman1440
Jul 9, 2012 01:09 AM
hawkwind
Aug 2, 2009 05:25 PM
ahawkins
Apr 11, 2008 07:35 PM
abramj
Oct 15, 2007 06:56 AM
