CARBURATOR LEAKS FUEL, ALL GASKETS FINE???
Old Jul 17, 2006 | 02:24 PM
MADETORIDE's Avatar
Default CARBURATOR LEAKS FUEL, ALL GASKETS FINE???
I just made a post about whether a 92 carb can replace an 88. But I figure I might as well just ask this question too. My carb leaks gas. I have taken it all apart, cleaned it out, checked all of the gaskets and even coated them with some gasket aid sealant. Well all this did was slow the leak down. Someone told me that these older carbs have a diaphragm inside that if it is not operating right, the carbs will build up a lot of pressure. I have no idea if this is what is causing the leak. Does anyone have any advice on the cheapest way to fix the bike. I am pretty limited on what I am aloud to put into the bike money wise.
Thanks,
Brad
Old Jul 17, 2006 | 03:05 PM
slowpoke's Avatar
Default RE: CARBURATOR LEAKS FUEL, ALL GASKETS FINE???
Where on the carb is the leak? If you took off the float bowl and cleaned the jets, you only cleaned half of the carb. The top part of the carb has the diaphram, piston, piston walls, needle, and air bleeds which all need to be cleaned. Well, not the diaphram. But if your carbs are leaking from a vent hose, then you have to replace the float needles and seats.
Old Jul 17, 2006 | 03:23 PM
MADETORIDE's Avatar
Thanks for the reply!!! They are leaking from the fuel bar (not the technical name) that distributes the fuel to the four carbs. Before I replaced the gaskets, it was leaking from where the main hose connects from the fuel filter to the fuel bar. I put on a new fasciner so it no longer leaks there. It does not leak out of the overflow tubes, and it does not leak out from sediment bowl gaskets. How would I go about cleaning all of the other stuff (piston walls, needle and air bleeds)?
bowtieboy42
F2 Tech
Apr 4, 2014 08:08 AM
RhodesRacing
Sep 7, 2013 12:45 PM
erick089
Dec 28, 2011 08:48 PM
Ragnaco
Jan 22, 2010 08:52 PM
dumptransit
Nov 10, 2008 09:36 AM
