Carburator help!!
Old Dec 9, 2011 | 12:31 PM
rjenkinscbr600's Avatar
Default Carburator help!!
I recived my carburators in peices.. i put them together after cleaning following the manual exactly..i am left with 4 small springs..i dont have a clue where they go.. please help. Thank you (1996 cbr 600)
Uploaded with ImageShack.us
Old Dec 9, 2011 | 04:18 PM
I could always continue without
Old Dec 9, 2011 | 07:05 PM
Ohiojc's Avatar
I've seen springs just like that on the pilot jets, I think it had a washer and o-ring at the needle end.
Old Dec 9, 2011 | 07:08 PM
Ohiojc's Avatar
Bottom of this diagram, number six: 1996 Honda CBR600F3 Parts, 1996 Honda CBR600F3 OEM Parts - BikeBandit.com
Old Dec 9, 2011 | 08:59 PM
Perfect! Thank you so much I also have 4 extra washers n rings haha thanks a ton!!
Old Dec 10, 2011 | 11:05 AM
Originally Posted by Ohiojc
No, that's not it. Item #6 is much smaller. The spring in the photo above is part of the carburetor synchronization springs. It's the upper spring here. There are 3 of them and they fit in between each of the carburetors.
After it's installed it looks like this.
This is item 6 mentioned above. It's brass and smaller.
This shows a dirty synch spring.
Post photos of the washers and rings you have and we'll see if we can identify them.
Old Dec 10, 2011 | 01:16 PM
I have 4 springs 4 brass washers 4 o rings. The carbs were already connected together
Old Dec 10, 2011 | 01:24 PM
I didn't put the springs in on that adjustable external valve. I wondered y it was a loose adjustment. My springs are brass and new to be put on like the photo 2 above this comment
Which side of the spring does the washer go? I can't believe the manual just says to put the valve in nd adjust it 1.5 turns out but doesnt mention the spring lol
Old Dec 10, 2011 | 03:26 PM
To install, it goes Spring, Washer, O ring.
Old Dec 10, 2011 | 03:33 PM
Thanks. I'm loving this forum already.
jasonchristopher
Jan 21, 2013 11:45 PM
landfast
Jun 13, 2011 05:56 PM
LJ Harp
Dec 26, 2010 06:28 PM
wjuranek2
Apr 22, 2008 09:02 PM
Delmustator
Mar 24, 2007 01:27 PM
