Carbs leaking fuel on 87 Hurricane
Old 02-07-2018, 07:23 PM
Thatsme4723's Avatar
Exclamation Carbs leaking fuel on 87 Hurricane
The carbs are leaking on a 1987 hurricane I'm buying and was wondering if it would be best to just replace the carbs all together and if so which kit is best to buy. Or what do you suggest doing/looking for when fixing it and basically if there is anything else I should know about this issue and related issues for this bike
Old 02-07-2018, 07:26 PM
there's a good chance that why it is leaking is just dry O-rings, cracked t-joints or a hose. Those are pretty easy to find and replace. Your going to have to tear into it regardless so I guess it's up to you on how much money you want to spend. Unless they've been really abused, carb bodies are pretty hardy things.
Old 02-07-2018, 07:32 PM
Ok thanks I'm not worried about tearing Into it at all I'm actually kinda stoked on fixing it the guy I'm buying from said about the needle seats may need replaced do you think that could be it? Mind you I am a NOOB and haven't really much knowledge about this stuff so anything you can tell me would be greatly appreciated
Old 02-07-2018, 07:52 PM
It could be. I personally haven't seen all of them go bad at the same time, but it is theoretically possible. They are very easy to replace.
Old 02-07-2018, 08:27 PM
Awesome thanks alot for the help I appreciate it
platnumbob
07-05-2014 09:57 PM
akubat
F2 Tech
08-16-2012 08:32 AM
MegatronousPrime
04-29-2012 09:51 PM
starturbo
05-16-2011 01:19 AM
dewdog
08-19-2010 09:16 AM
Quick Reply: Carbs leaking fuel on 87 Hurricane
