Camshaft question
Old Mar 19, 2018 | 08:50 PM
Cbr900rz's Avatar
Default Camshaft question
Hi, I have a 96 cbr 600 f3 and im trying to get the timing correct. I have everything lined up. I have the 1 cylinder at tdc and rotor lined up with the T.. I have intake sprocket lined parallel with the head. But the exhaust cam sprocket is a little off. My question is can i just take the cct back off and take the exhaust cam sprocket off and leave the crank lined up with the T and the cam intake sprocket parralle with the head but move the exhaust camshaft with my hand a little till I get it parallel with the head.?
Old Mar 20, 2018 | 12:25 AM
ceebeeaarguy's Avatar
Yes of course. remember you can do whatever you want with the cams in whatever order(although Haynes I think recommends one of the cam to be linedup first not sure which one though)but at the end of the day they should line up
Old Mar 20, 2018 | 02:16 AM
hk3's Avatar
hk3
I ended up having the cams off several times to juggle my existing shims. I didn't take the sprockets off the cams, and after doing it a few times I could get the cams lined up in a minute or two. That might be easier than taking the sprockets off?
But if you do decide to take the sprockets off:
Old Mar 20, 2018 | 07:53 PM
Cbr900rz's Avatar
Thanks everyone for the replies. I finally have the cams in time with the crank. And I have the engine mounted back inside the frame. All I have to do now is hook everything back up and hope it runs.lol
Kinked_Chrome
Apr 30, 2008 12:42 AM
mentor
Mar 31, 2008 03:29 AM
woo545
Mar 26, 2008 05:40 PM
mikeyvis
Dec 23, 2006 10:57 PM
Marineborn
Jul 29, 2006 11:21 AM
