leaking oil from camshaft chain adjuster bolt Help???
Old Jul 29, 2006 | 02:47 AM
Marineborn's Avatar
Default leaking oil from camshaft chain adjuster bolt Help???
okay im pretty sure its leaking fomr the cam shaft chain manual adjust bolt cause 2 days ago i took it out and put it back in to adjust my chain and it started leaking then, so should i put something on the threads of the bolt, how should i stop the leak?
Old Jul 29, 2006 | 11:21 AM
rocketjoe's Avatar
Default RE: leaking oil from camshaft chain adjuster bolt Help???
Did you make sure the rubber ring that is around the bolt is seated , to help seal. That would be my first guess if it is leaking from the bolt. Now if it is leaking from around the base I would say take it off and put some high temp. sealent on .
lhall6649
F3 Wanted
Oct 12, 2010 07:24 PM
TrikyShooter
Jun 17, 2010 12:48 PM
Campbell45
Jun 16, 2010 12:54 AM
Rabid
Jun 24, 2008 03:52 PM
1000RRSwede
Jul 27, 2006 07:55 PM
