Cam Chain Tensioner issue
Old Oct 12, 2004 | 06:36 PM
Duke's Avatar
Default Cam Chain Tensioner issue
I'm sure most of you are aware of the CCT issue with the F4i's.
I'm on my second one and it is now shot. Didn't even last a year. I had Honda replace it free, but got stuck paying an hour labour. I now need to have it replaced AGAIN! [:@]
Suggestions? Anyone have success with one type/brand over another?
Old Oct 12, 2004 | 06:53 PM
sirlimpzalot's Avatar
Default RE: Cam Chain Tensioner issue
A.P.E. has manual ones that you adjust every so often. Make sure you orderthe new gasket when you order the tensioner. www.aperaceparts.com is the website. They have all sorts of stuff for high performance applications.
The manual tensioners are not very expensive either
Old Oct 18, 2004 | 04:10 PM
Duke's Avatar
limpz....
i think i heard that the manual tensioners are a pain in the azz to adjust. is this true?
if not, how long, how much effort is required?
thanks.
Old Oct 19, 2004 | 03:03 PM
it is easy to adjust..just you have to get to it since it behind the frame spar, you have to go from the top by removing the tank and getting past the carbs/throttle bodies..just adjust it until it snug and back it off just a touch...once you do it it isnt that hard...
Old Oct 20, 2004 | 12:03 PM
Duke's Avatar
yep, that's what i thought, sounds like a pain.
removing the tank and all.... sheesh.
oh well, beats the annoying noise that it is making now.
how often do they need to be adjusted? any idea?
thanks for the info.
Old Oct 26, 2007 | 09:28 AM
mspooner's Avatar
i got a cbr 1992 250 and i got a tickin noise on low revs... i think its the timing chain but not too sure can anyone tell me if its a common prob and how do i adjust it if i can?
NobleSandy
Mar 29, 2010 12:30 PM
pimpax56
May 27, 2009 12:18 PM
doughboy900rr
Apr 16, 2008 12:16 AM
mikequinn
Aug 29, 2006 12:37 PM
ozrider
Feb 7, 2006 02:02 PM
