Cam Chain Tensioner
Old May 27, 2009 | 11:49 AM
pimpax56's Avatar
Default Cam Chain Tensioner
Hi i just got my APE cct today and i was reading up on a couple threads on how to install it. Some threads say that its just a r&r but another thread said that you need to move you pistons to TDC before removing the stock cct. Some extra info can help before i start anything thanx!
Old May 27, 2009 | 12:15 PM
Incognito's Avatar
Official CBRF Welcome Crew Undercover Agent
Smile
I switched mine out also, and no, you don't need to have it at TDC. Put the bike in neutral and don't move it while you install it & you'll be OK.
One thing I did to adjust the tension on it was to install it on, then screw in the adjuster until you feel resistance with moderate finger pressure. Start the engine and continue to apply very slight turning pressure to the adjuster. You will notice that it will creep inward (tighter) as the engine turns. Eventually it will reach a point that it won't want to go in anymore (again, with little turning pressure); that'll be your sweet spot. It took me a couple of tries to get it right.
Have fun, and remember; patience is a virtue, lol...
Old May 27, 2009 | 12:18 PM
teko1020's Avatar
http://cbrworld.net/forums/thread/85183.aspx
Speedemon636
May 8, 2010 06:27 PM
njens118
May 4, 2010 03:44 PM
nikos
Feb 25, 2009 02:05 AM
ozrider
Feb 7, 2006 02:02 PM
radio one
Nov 8, 2005 11:38 PM
