Break In Oil
Old Jul 18, 2007 | 11:36 PM
speedfever22's Avatar
Default Break In Oil
Just bought a 07 1000, Time for oil change, This is the most confusing part of owning a bike. Some say synthetic, some say the rings won't settle properly. Others say there full of ****. I have read all these articles about different kinds of oil. I'm to the point of going to the local parts store and using flipping a coin method to pick some out. I'm not the one to have to order oil from a parts store and pay $8 a quart when the **** is more than likely made at the same place like automobile tires, suntan lotion. Anyone have a good all around oil that don't take a week to get here and a weeks pay to buy. Something that is simple and affordable.
Thanks again for a kick *** forum to discuss these issues.
speedfever22[sm=americanasmiley.gif]
Old Jul 19, 2007 | 12:25 AM
lungfish13's Avatar
Default RE: Break In Oil
I run amsoil in all of my vehicles and haven't had a problem yet. My dodge has 160,000 miles on it and the only work i've had to do to it has been a new timing chain and the normal routine maintenance, brakes, tires.... I went synthetic on the CBR after the first oil change and haven't had any issues either. Firgure if cars are coming from the factory with synthetic then it can't hurt. If you take care of your ride then you shouldn't have any problems is how I look at it.
Old Jul 19, 2007 | 05:08 AM
Blue Fox's Avatar
Retired Moderator
There is literally a BAGILLION threads about this all over this site. Search for it and you'll get all the info you need.
Old Jul 19, 2007 | 06:16 AM
fishfryer527's Avatar
Blue Fox is wrong...There are two BAGILLION threads about this...
Search.
Old Jul 19, 2007 | 07:14 AM
MikeInCtown's Avatar
FWIW do not use synthetic at break in. Even the Amsoil website tells you that their product should be used after break in. As asked, synthetic is made to reduce friction more than standard oil and it's true that the rings need to seat properly along with everything else in the engine. (clutch plates, etc)
Old Jul 19, 2007 | 08:36 AM
Streetdemon's Avatar
I ♥ CBRF
Tons of opinions and no right or wrong answer. I run Motul semi-synthetic blendwhich is easy to find at a goodbike shop (6 bucks a qt). Honda says to stay away from fullsynthetic altogetherbut once I hit about 15Kmiles I'll probably run it. I agree with Mikeinctown, stick with a non synthetic for at leastthe first few thou for break-in.
Old Jul 19, 2007 | 09:25 AM
Tahoe SC's Avatar
just bust the honda GN4 stuff recommended in the manual and forget all the debate.
Old Jul 20, 2007 | 12:05 PM
Hayden06F4i's Avatar
ORIGINAL: Tahoe SC
ME TOO.
Old Jul 20, 2007 | 03:32 PM
jmdaley's Avatar
Same here. After debating it and using it for a while, i decided that chances are i'm not going to have any of my vehicles/bikes long enough to see any advantage from synthetic.
Congrats on the new bike...it's one of my personal favorites.
Old Jul 21, 2007 | 12:12 AM
Thanks for all the help, I did read a lot of forums on this oil debate, It never hurts 2 get a few more. thanks again for the advice.[sm=smiley20.gif]
Grego2582
Mar 27, 2013 06:13 AM
raylee
Mar 8, 2010 10:57 PM
alleycat
Oct 10, 2007 11:20 AM
ctskydive
Aug 20, 2007 05:23 PM
Drekkyk
Jun 9, 2007 12:00 PM
