Blown Head Gasket?
Old Oct 18, 2017 | 06:01 PM
MinorDetail's Avatar
Here’s a video I recorded.
Old Oct 18, 2017 | 06:42 PM
74demon's Avatar
That's a pretty big leak. I don't think the water pump would leak that quickly. You could pinch the hoses with clamps/vice grips and add water again to see if it holds.
Did the water level reach the head gasket?
Drain all the water and add slowly, noting where the water level reaches when it comes out.
Old Oct 18, 2017 | 07:15 PM
I don't know if it reached the head gasket, probably put a half gallon in before it started coming out the first time. The video was the second time. I'm not sure how to observe the water level. Any tips on that? I can see a quarter inch or so of water sitting in the oil pan looking through the crank case in the right side of the engine.
Old Oct 18, 2017 | 09:02 PM
EchoWars's Avatar
Jeebus!
Have you done a compression test?
Anyway -
Since the water that came out of the water pump drain bolt was clear my assumption was the oil cooler seals weren't at fault
You know what they say about assumptions...
Get the oil cooler off of there and see what's up. Water pump too.
Old Oct 19, 2017 | 06:59 AM
Originally Posted by EchoWars
Jeebus!
Anyway - You know what they say about assumptions...
I have not done a compression test yet, I will plan on doing that next.
I pulled the water pump last night and it appeared to be fine, not cracks or anything. I'll pull the oil cooler as well, no more assumptions on my part! haha
Old Oct 24, 2017 | 12:08 AM
SunBlue's Avatar
Holy **** wth!!!! That is crazy. Please let us know when you find the issue, I'm so curious now.
Btw, your garage looks rl nice. Is that a bed in there??
Old Oct 24, 2017 | 04:26 AM
I’ve ruled out the water pump at this point, clamped the hoses and it held water. Next up is replacing the oil cooler seals, then a compression test. I’ll definitely report back.
Thanks man, haha yeah it’s a mattress under a little climbing wall I built in there.
Old Oct 24, 2017 | 05:26 AM
74demon's Avatar
Which hoses did you clamp off?
Old Oct 24, 2017 | 05:33 AM
I clamped the large hose going to the oil cooler and the two smaller hoses coming off the water pump.
Old Oct 24, 2017 | 10:32 AM
74demon's Avatar
Did water make it into the engine block?
If you took the pump out of the circuit and it held, then the pump could be leaking. You could remove the pump and unclamp the hoses and watch it leak....or not.
Does the cooler feed hose isolate the cooler? I have a different set up, so I'm unsure of your cooler's routing.
