Bike hesitates at low RPMs?
Old Mar 14, 2011 | 09:44 PM
Leugs31's Avatar
Question Bike hesitates at low RPMs?
Hey fellas. I was wondering if anyone could help me with this issue. I have sold the cruiser and bought a sportbike. It is a 95 honda cbr 600 f3. it runs strong out on country roads when the RPMs are up but when i am putting around through town its sounds horrible. It almost seems like the bike hesitates and is jerky. I was just wondering if this is common for sportbikes or not? I bought a couple of bottles of Seafoam and ran them through the engine but it doesnt see like it did much. Any suggestions on what I can do to make her purr like a kitten at low RPMs? Thanks.
Old Mar 15, 2011 | 02:24 AM
gunslinger1274's Avatar
Is everything stock on the bike?
My exhaust was upgraded then the can was cut, (stunter's bike) and I had similar issues, rough idle, a little hesitant in low RPM's, somewhat jerky with the throttle. One mechanic told me it needed to be jetted. Now, don't take this as experienced advice, because I am new to sportbikes also. Just what one suggested it may be. Just offering up one possibility.
Old Mar 15, 2011 | 02:34 AM
justasquid's Avatar
You may have to be a little specific as to whats it doing. Is it low throttle input? or RPM related? Is the engine actually missing? Or is the bike just a little jerky?
However, since you are coming from a cruiser, its hard to get in the habit of keeping the rpms up and that could be your issue. These bikes do not like really low rpms like a cruiser does. Inline 4's really like their rpms. Im not sure what rpms your running in, but they are much higher on an inline 4 than on a twin. I'd say try not to let them drop below 4 grand and see if that helps. I've had a few friends that have made the switch and it takes them a long time to realize the rpms need to be higher. Its a hard switch to see what use to be your redline, now be your cruising rpm.
Also, make sure your chain tension is correct. A loose chain will give you that jerky feeling at low speeds. Its much more noticable on a sportbike than a cruiser if the chain is loose. Also, make sure its not binding or dirty. These chains require some maintenance, so make sure to keep up on it.
kahrens46
Sep 26, 2013 07:47 PM
MiniMafia
Nov 22, 2012 10:23 PM
HellrazerinDC
Feb 22, 2012 02:49 PM
rrspeedster88
Mar 21, 2009 10:36 AM
jeffrimerman
Jul 7, 2006 03:48 AM
