Battery won't charge well
hi my 2003 cbr600rr battery does not charge well. Ok let's say I warm the bike then drive 2 miles, my bike does not have the battery start unless I wait 1 hour. It start fine again. I emailed the seller, he claims the battery was recently changed. I guess something wrong with the charging system? How much will it cost and how to fix it?
on
1 Post
RE: Battery won't charge well
Its probably that your regulator has had the Richard, common problem (like every bloody CBR).
Draws current from your battery, don't know wot you guys will pay to have it replaced, do a search, there has to be dozens of posts about this one. Don't buy a OEM replacement, get an after market heavy duty unit so it won't stuff up again.
on
1 Post
Ok, your voltage regulator is faulty (most probable cause) Could be a bad battery, but I doubt it. It over heats, then stops working, so your bike then drains power from the battery. The reg is located on the right side rear of the bike, attached to the frame. The faults starts intermittently at 1st, but the reg brakes down, so eventually it stops working = flat battery. Replacing it with a heavy duty item (read BIGGER heatsinks) will stop this from happening again. It cost me about $200 (Australian) to have it done, with a very minor adjustment for mounting it (cause its bigger).
Before you do any of this take the battery to autozone and have them test it. How do you know the last owner really did replace it? Even then maby the battery just isn't holding a charge? I drained my last battery by accident, I left my bike on for hours. I jumped it with a car and road home and put it on a trickle charger. It would only hold a charge for about 1 day. It kept dieing on me and I thought my bike wasn't charging it right. I finally went to Walmart and bought a battery there. Poored in the acid, stuck it into my bike, and road off. Ever since then its work, no problems at all.
ORIGINAL: pacemaker
ok thanks for all the inputs. I will go to walmart or sears and purchase tools to take the battery. And if the battery is fine, I will get a wall charger so that I can ride it to bike shop and have them to take a look.
i have a silly question though. are those steps to push start?
1- turn ignition on
2- hold clutch and go to gear 2
3- ask someone to push me
4- let go clutch and apply little throttle
do i need to use the start button at all? the little red button on the right
by the way, i found a really useful link:
http://cbrworld.net/forums/thread/140473.aspx
1- turn ignition on
A hill to roll down works well also. Here is a note to self, if the battery is too dead, the bike will not start when trying to push start. But for the most part, those are the steps for push starting. Ifno one is around to help out, you canpush the bike yourself and then jump into the saddle. Then try starting step 4.
