F4i charge battery help
Old Mar 20, 2010 | 07:12 PM
prowheelie92's Avatar
Default F4i charge battery help
i was wondering how to remove the front seat on a 2001 f4i. I just got the bike and the battery is dead. i got a trickle charger. I also need help on where to connect the trickle charger and to use 6v or 12v and also where to connect the cables. Thank you
Old Mar 20, 2010 | 07:25 PM
nmutroy's Avatar
Pull back the foam near the back of the seat and you will see two bolts. Remove them and your seat will then come off. Move the box under the seat to the side and there will be a cover...lift up the cover and there you will find the battery. Really easy to do...good luck
Old Mar 20, 2010 | 07:26 PM
nmutroy's Avatar
Pull back the foam near the back of the seat and you will see two bolts. Remove them and your seat will then come off. Move the box under the seat to the side and there will be a cover...lift up the cover and there you will find the battery. Really easy to do...good luck. Connect the cables right to the battery. Pos to Pos and Neg to Neg.
Old Mar 20, 2010 | 07:53 PM
thanks do u know how many volts to use
Old Mar 20, 2010 | 07:55 PM
nmutroy's Avatar
12v
Old Mar 20, 2010 | 08:03 PM
thanks
cncquinn
Oct 8, 2011 06:31 PM
lyons_02
Jun 15, 2010 06:22 PM
Had
May 7, 2009 05:15 PM
null84
Dec 9, 2007 09:36 AM
fightingillini
Sep 15, 2006 02:20 PM
