Any LED ideas??
Old Jul 12, 2007 | 01:41 AM
ilikemybike7's Avatar
Default Any LED ideas??
Hey guys, I bought 50 led's off of ebay for $6.00, can't go wrong atleast price wise. I want to use them to act as neons. I have enough resistors for each one. What I currently did: Took 20 of the orange LED's and wired them into pairs to form 10, then wired the ten LEDs in a series (i think tht's right) of off a main power and ground wire coming from the battery. The 12-volt application resistor was wired in on the positive side before the swith. Anyways, when the LEDs are on, you can see them, but only if you actually look inside my fairings. I want to have that neon/glowing effect. If there is a way, or it isn't possible at all, how can i get them to shine brighter? Any ideas and/or comments are more than welcome.
Old Jul 12, 2007 | 07:00 AM
lotusgardener's Avatar
Default RE: Any LED ideas??
Get a reflector, Radio shack should sell them, if not lowes, HD, or even a crafts store. Its the thing that your taillight is housed in in case you don't know what Im talking about.
Old Jul 12, 2007 | 09:45 AM
Triax's Avatar
remove the resistor, a single led usually takes .8V to 1.8V and with a series of ten and only 12V going to them you are blocking current they need to be brighter.
Old Jul 12, 2007 | 12:39 PM
Okay, after looking at everything, I came to realize that they are actually wired in parallel. One thing I was thinkin about too, is that maybe since the lenses are clear, they won't glow as much.
Old Jul 12, 2007 | 01:05 PM
Triax's Avatar
they should glow brighter being that they have less tinted glass to go through.
Old Jul 12, 2007 | 01:39 PM
OKIEZAC's Avatar
neons are cheap... and kinda gay.. just get them unless you like tinkering with your bike..
Old Jul 15, 2007 | 12:13 PM
Woody900's Avatar
Go to JoeFlorida's website, I installed 22 LED's I bought from him off of e-bay. He gives you step by step instructions and has some of the best lights i've ever seen. As long as all the lights are wired together (all positives and all negatives which sounds like you did) then each light should only draw approximately .003 milliamps.They'll run from the fuse, to the on off switch,to the neg. and pos. of the battery. I'll send you some pics of my bike at night... you can see it glowing from a mile away -the thinglooks like a monster! And to the comment from OKIEZAC-- They are not NEONS, they are custom LED (Light EmittingDiode) show lights, and they happen to be one the best way's to trick out your bike and make it stand out. Don't knock somebody elses idea's because you're to lazy to take the time to do it yourself. Show some pride in your ride. Anyway, post some pics of your bike when you get done ilikemybike7. GOOD LUCK[>:]
kinglopaka
May 15, 2011 08:20 AM
Dan122087
Apr 19, 2011 06:58 PM
FoxRacin17
Aug 21, 2007 07:18 AM
charlos
May 9, 2007 06:51 AM
JBaz
Nov 10, 2006 05:10 PM
