Any ideas?
Old Aug 20, 2007 | 11:45 AM
FoxRacin17's Avatar
Default Any ideas?
Ok, one of the little pieces that holds the plastic on broke off the rear side faring. its the one farthest to the back by the taillight. is there any way to put it back on? like caulking, or some kind of really strong glue or adhesive stuff? it makes the piece over the taillight and the side faring have a little gap there and i dont like that. any ideas?
Old Aug 20, 2007 | 01:52 PM
Northernfirepower's Avatar
Default RE: Any ideas?
Two words...black tape! LOL That's what I used for a temp fix. If anything else, fab up a piece to go under both pieces and fasten them together. If you want pretty, your main resort is to look for a replacement.
Old Aug 20, 2007 | 02:02 PM
madmike01uk's Avatar
Someone on here hadfrabricated areplacement metal part that he was going to sell on here, I can't remember his name but it looked like a good solution, try and do a search to see if you can find him.
Old Aug 20, 2007 | 02:18 PM
https://cbrforum.com/m_328355/tm.htmtry one of these.
Old Aug 20, 2007 | 04:40 PM
redzintimidator's Avatar
epoxy? Gorilla glue? Super glue?
Old Aug 20, 2007 | 08:39 PM
410600f2's Avatar
Iused a plastic weld two part epoxy to fix my rear side plastics( the mount that goes into the rubber grommet on frame) and also fabbed up an entire corner that broke of the rear corner (by the tail-light). Its great stuff,its fully sandable in 15 minutes. Make sure to get "plastic weld" the other epoxy is crap. Make sure to scuff up and wipe down area with some kind of degreaser.
Old Aug 20, 2007 | 09:04 PM
FoxRacin17's Avatar
um, do you have to weld that? how is that done? a regular welder? and where do you get this stuff from?
Old Aug 21, 2007 | 07:18 AM
410600f2's Avatar
plastic weld is a two part epoxy you can pick up from any auto store. http://www.permatex.com/products/aut...astic_Weld.htm
kinglopaka
May 15, 2011 08:20 AM
Dan122087
Apr 19, 2011 06:58 PM
ilikemybike7
Jul 15, 2007 12:13 PM
charlos
May 9, 2007 06:51 AM
JBaz
Nov 10, 2006 05:10 PM
