spark plugs, never done this before
ok so i have a 96 f3 and the plugs need changed but i have never done this before and i really dont want to screw anything up. it looks from my clymer and stephygee manual that theyre under these red rubber tube things. are they inside the sleeve or down in the hole. seems like they were down in the hole from where i felt the threading on something. how do i get them out? im sorry guys, im new to this but want to learn
Yes they are down the hole, if you have a tool kit with your bike you should have a spark plug tool which makes them easy to get out. Make sure you put the HT leads in the right order when you re-fit them.
ORIGINAL: madmike01uk
you don't want to force it in (big mistake) if you thread it you are looking at some major work to re-thread the hole.
Be careful
Good luck
Be careful
Good luck
Yes and no...the head would be fixable but you cant just rethread it yourself with a tap...you would need to do a helicoil job...a huge pain in the ***! Far better off to just take it slow and steady and never force it!!
Dennis
Dennis
