Alternator problem
Old Aug 6, 2007 | 02:37 PM
wesku's Avatar
Default Alternator problem
Battery drained empty when riding. After charging battery noticed that just less than 13 V to battery even with high rpm. When measuring yellow leads to stator with ohmmeter shows less than one ohm between leads and 1.2-1.3 ohm from lead to gnd. After taking off the alternator cover noticed that the roller bearing is broken all the ***** out.
Any ideas how to get the bearing inner part away ?
What else will be broken if bearing fails like this ?
Pictures
Old Aug 22, 2007 | 03:26 PM
wesku's Avatar
Default RE: Alternator problem
Now have replaced the bearing but still no charge. Is it so that there should be high resistance between yellow wires and gnd ?
Old Aug 22, 2007 | 04:42 PM
MikeInCtown's Avatar
Look for the service manual for your bike oin PDF form. It will have the specifications for the stator output and resistance readings. You should also check the wiring to the regulator as well as the regulator itself.
hmm
Aug 28, 2013 07:21 AM
SILVERBIRD
Apr 29, 2008 09:54 PM
Speedracer
Jul 5, 2007 09:11 AM
hasfidanken
Sep 29, 2006 09:46 AM
