Alarm misfunctioning
Old Jul 12, 2006 | 01:45 AM
929 FRB18's Avatar
Default Alarm misfunctioning
I have a spyball alarm on my 01 929, it used to be loud as anything before, thats the problem though, used to be...
only thing i can think of that would have an affect on the alarm is my battery died, i've had to jump start and re-charge the battery a few times, its now been replaced and is fine. i didnt notice if it was making noise before that or not, all i know is, it used to be very very loud and very sensitive, now, i can move it or do what i want with the bike, all that happens is the blinkers blink for alittle while and stop. any auto electricians out their? any ideas as to why this would be? would it be because of the battery?
Old Jul 16, 2006 | 02:08 AM
mxman87's Avatar
Default RE: Alarm misfunctioning
The battery dieing isn't going to cause the alarm to change the way it acts, as long as the new battery is fully charged. Go through and check the ground connection for the alarm, and siren if they grounded them seperately, this sometimes becomes corroded or loose. After that check to see if you are getting a full 12 volts to the alarm. Let me know what you find out and we'll go from there.
Old Jul 16, 2006 | 09:15 PM
929 FRB18's Avatar
i checked all the wiring, checked the voltage with a multimetre, and everything appeared to be fine. the only thing i can think of is somehow the siren itself is damaged. which i dont see how it could possibly happen as the bike has never gone down and this problem occured literally overnight...
thanks for your ideas, what do you think could be the problem?
Old Jul 17, 2006 | 01:16 AM
mxman87's Avatar
When the alarm is going off what is the voltage at the siren wire?
Old Jul 29, 2006 | 04:16 AM
CBRMan2's Avatar
I have instealled CAR alarms for the past 11 years, and the circuitry should be the same... Whenever you have an alarm on a vehicle and jump start it, u run into the risk of a surge flowing through the wiring and causing it to burn out..If your alarm is soft sounding, and it flashes for a second and stops with or without dim lighting sounds like a burnt out circuit which means it should be replaced or serviced.
MuleDoe
Apr 22, 2009 10:38 PM
smitty911
Mar 14, 2009 03:30 PM
skitzofrenzy
Sep 1, 2008 06:22 PM
tillersluck1117
Mar 26, 2007 01:48 AM
lang1864
Jun 9, 2006 04:32 PM
