new alarm set up
new alarm set up
i bought a used chatterbox alarm system, yeah i know i didnt know they made alarms either, but it was cheap and it works. im going to diy on the install, only prob is im stuck.
where the hell do i mount this thing? its like three by five inches and needs to be somewhat protected from heat and water.
also, on the instructions it says to put these two blue wires onto the starter motor relay, but (see picture) it looks confusing. does that diagram mean to put the one wired in the relay wire at one point, and the second blue seperated from it, spliced into the same where?
any help is appreciated
RE: new alarm set up
once you find yer starter wire you wanna cut it, now you have two wires, connect these to the two blue wires from alarm,it dont matter whih is which (thats why their both blue) this just opens and closes the starter circuit at the right time,
and im not sure what bike you have but you should be able to make some space under threseat for the brain!
