95 CBR 600F3 Float height adjustment
Old Jun 7, 2022 | 02:32 PM
StephenD's Avatar
Default 95 CBR 600F3 Float height adjustment
Two floats are clearly sitting lower than the others in the float bowls, and the two don't have as much bounce as the other, how do i adjust the height so the floats are laying evenly and have the proper bounce??
Old Jun 7, 2022 | 03:12 PM
They aren't adjustable. There are three components to that area: the float, the float needle and the pin that holds the needle in place. The bounce comes from the needle. It has a tiny spring in it. To test, you just push on the little nipple with your fingernail or a flat blade. It should have a crisp return when you let off pressure. It it doesn't, you can soak it in parts cleaner for just a little bit. That might help. The other thing it could be is they float might have a hole in it and doesn't float. That's super easy to check. Basically if it has fuel in it, it's bad.
Old Jun 7, 2022 | 06:30 PM
StephenD's Avatar
Got it running, its bogging a little bit still on accelerations in 3rd and higher.
New floats and float needles, One side of the floats, is setting lower than the other side, one side when I tap it its bouncy but u can hear the float hit the bottom of the float bowl, the other side is plenty bouncy and doesn't hit the float bowl when I tap it, Idk if that would cause a bog
also when initially cleaning the carb I didn't watch where I put the jets, I do if that has anything to do with it?
Old Jun 7, 2022 | 08:07 PM
Sounds like the float needles are not the same. No adjustment as Hamlin6 said. If they don't sit the same, then you have to replace.
Rollo87
Alternative Parts
Sep 26, 2014 07:29 PM
axehind
Rides
Jul 25, 2011 12:06 PM
ebinz88cane
Mar 1, 2010 02:01 AM
tygracia
Jul 9, 2006 05:56 PM
furious82
May 18, 2005 08:32 AM
