94 900RR carb woes
Old 01-19-2009, 12:01 AM
RedBlackandWhite 94's Avatar
Default 94 900RR carb woes
I brought my bike to Sea Level last Febfrom the high desert 4400ft at homeup to 9000, yeah lots of mountain roads! The bike was set up for high altitude and screamed up there. Got it here and it got progressively worse at starting and seemed to flood easily first time, then started good when warm (without touching the throttle!)It got cold and sat for a month and hasn't started since. Justput astage 1 dynajet kit in and gave them a good cleaning, changed plugs, and did a fuel pump check just because. I messed with the idle screws so they arenot set as removed. Now when it turns over with the choke onit runs up the 4k to 6k rpms and dies, or it chugs a couple times and dies, or, it idles about 1000 rpmsas long as the chokes out then dies. Any throttle movement orshutting off the choke kills it. The float bowls are getting fuel, the plugs have spark, and the air boxis off.Iset the fuel screws per the jet kit, 2 turns out, and the manual 2 1/2 turns out with nolove. I'vedone all this work before without a hitch, can't seem tofigure this one. I havea KN filter and Vance and Hinesfull pipe.I did put in bigger jets this time 24's vs 20's. Havecarb stick to sync but need toget her to idle. May pull them in the morning and recheck, but I'll try one morecycle on the battery to try athree turns on the fuel screws, saw it on another site!?I'll try and get somepic's posted too. THNX
Cheers
dirtrider0202
05-11-2013 05:15 PM
+turbo
10-24-2010 09:23 PM
Zach
09-28-2009 06:45 PM
eukanuba517
11-25-2007 10:59 AM
Quick Reply: 94 900RR carb woes
