Carb sync 94 900rr
Old Oct 13, 2010 | 11:49 AM
+turbo's Avatar
Default Carb sync 94 900rr
Hello everyone I have a 94 cbr 900rr that I want to sync the carbs. I made a homemade carb sync tool and need to know where to connect the hoses. In the engine I have some vacuum lines that have been plugged and suspect that this is where I sync them. The lines come from the intake manifold right below the carbs on the back side of the engine(side closest to the seat) are these the lines? Or do they connect to the carbs? If any one can help please or post a pic. I have a petcock that has no vacuum hose
Old Oct 13, 2010 | 06:28 PM
Stien514's Avatar
On the back side of the head where the carbs attach via the rubber boots(1 per carb, per cylinder) You'll see a small rubber plugged off hole on the underside of the intake ports. This is the point where you connect the lines. You'll need I think a 5mm threaded nipple to connect your sync gauge lines.
Old Oct 13, 2010 | 07:04 PM
+turbo's Avatar
Ok thanks that's what I was talking about but I wasn't sure thanks again
Old Oct 14, 2010 | 06:11 PM
Hondas Rule's Avatar
The easiest way is to buy a mercury sync for about $50, Or find someone who has one. Or 4 vacuum gauges work, Where are you located? I am in NorCal and have a set if you are close
Jim
Old Oct 15, 2010 | 05:40 PM
+turbo's Avatar
Where can I get a mercury sync for 50 bucks
Old Oct 22, 2010 | 11:41 AM
cbr900racer77's Avatar
Not sure what they cost nowadays, but I have a MotionPro merc. set.
Old Oct 24, 2010 | 09:23 PM
Motion pro makes them, Try denniskirk.com or maybe motosport.com
TooSlow
Apr 21, 2025 04:09 AM
compster
F2 Tech
29
Jun 5, 2012 12:28 PM
subyman1440
F2 Tech
Feb 12, 2012 04:19 PM
dakers0010
Sep 15, 2010 09:23 PM
My89CBR600F
Sep 20, 2006 01:30 PM
