929 No headlights/marker lights
Old Sep 30, 2006 | 06:18 PM
Tricky9two9's Avatar
Default 929 No headlights/marker lights
I rode my bike monday and everything worked great. Went to ride it weds. and started it up and no h/lights or marker lights, but the tail and brake light works. Checked and changed the fuses but no go. The fuse block does have power to and from it. Got the whole front end off and cant seem to find the problem. Any IDEAS???
Old Sep 30, 2006 | 07:29 PM
outsider8's Avatar
Default RE: 929 No headlights/marker lights
check the engine start/stop switch-when lights are working-they shut off when starting engine-then switch back
on once engine is running-sounds like the switch is in permenant start mode!!!
Old Oct 2, 2006 | 02:46 PM
01929RR's Avatar
I had the same problem last week, not sure about marker lights though i dont have any. The problem was in the starter box on the right clipon. There is a wire thats soidered on that broke off. I resoidered mine and it works agian. Good luck.
Old Oct 6, 2006 | 08:58 PM
Thanks ill try that and see what happens
Broheim
Nov 1, 2008 03:11 PM
Archer 900RR
Sep 15, 2007 12:56 PM
bajaroots
Sep 8, 2006 10:12 PM
NotSoMellowYellow
Jan 1, 2006 12:42 AM
NotSoMellowYellow
Dec 31, 2005 11:22 PM
