lights in headlights?
Old Sep 14, 2007 | 03:08 PM
Archer 900RR's Avatar
Default lights in headlights?
I have scrolled through every 929RR/ 954RR/ How-to threads, and I have yet find anything on what people have used, how they did it, recommendations?
Any input on this would be great as well as pics!
Thanks guys/ girls
Archer
Old Sep 14, 2007 | 04:27 PM
Triax's Avatar
Default RE: lights in headlights?
Check out our sponsors they have some nice H7 bulbs. Theirs a thread or two about the HID kits on here somewhere.
Old Sep 14, 2007 | 07:18 PM
yeah I was looking at that. So the H7 is what I want to use in the corners of the headlights?
See I just bought this 929 this past monday after I sold my 900rr that I JUST finished rebuilding... Its a sickness, so now I am taking another fall/winter to rebuild this 929rr to be something amazing! I just want to make sure I do this right.. know what I mean? So now that I know what bulb to use, what about the thing the bulb goes into?
Archer
Old Sep 14, 2007 | 07:40 PM
ApexClipper's Avatar
Have you consideredusing the corner area for turn signals? That was done on some Euro versions and I've seen a write up onhow to modify the headlight for thatbut I can no longerfind it anywhere. Either way it involves cutting holes on each side to accept some kind of bulb receptacle obviously. I'll keep looking for that write-up and post if I find it.
Old Sep 14, 2007 | 08:01 PM
that was the whole idea... lol I saw it on a euro spec bike on RRzone
I think its awsome, So I just have to figure out what Im going to use, I know I need to drill into my new headlight i just recieved.
Archer
Old Sep 14, 2007 | 08:12 PM
well I did some searching around and found this site. Its actually pretty cool. have some neat halo things for the 929/954. check it out, it also have the euro turnsignals on it, course im not paying $50 when I can do it myself..
http://www.fendereliminators.net/
Old Sep 15, 2007 | 09:19 AM
bukwld360's Avatar
I have never personally modified a headlight assembly for the 929, but I have done it for a 94 Accord EX that I had customized. I wanted to keep the stock tail lights, but give it something custom. I basically took out the stock tail lights, and swapped the turn signals for reverse lights. It involved some cutting in order to get out the amber film that was on the turn signal side.
But if you wanted to modify the front headlight to accept the turn signals, either buy a replacement light assembly and drill a small hole into your light assembly and install. You can get a custom fit grommet from any car parts store and do it that way. This way no water will get into your headlight assembly damage anything.
Or you could take off the stock light and use it that way. This might require you to extend the wires, so be prepared to cut/re-connect/crimp if it calls for it.
Once again, I've never done this but if your tight for money and think you can do it yourself, this is an easy way to go, and it worked well for import cars.
Old Sep 15, 2007 | 11:51 AM
Triax's Avatar
Try this site. I think this is similar to what you are looking to do.
http://www.cbr929rr.com/brow.htm
Old Sep 15, 2007 | 12:56 PM
yeah I have that saved in my favorites.
Didnt see it till I was looking this morning. Shouldnt be too hard to figure out. time to waire up some LEDS I guess...
Archer
xankriz
Apr 2, 2012 03:02 PM
deerslider
Aug 24, 2009 08:23 PM
Ocelaris
Dec 7, 2006 02:14 PM
Tricky9two9
Oct 6, 2006 08:58 PM
kid M
May 21, 2006 04:11 PM
