92 f2.....will start with choke on but cuts off when gives gas.
Old Jun 25, 2010 | 04:02 PM
elusions's Avatar
Default 92 f2.....will start with choke on but cuts off when gives gas.
i just fifnished an engine swap and now im trying to figure out how to make this bike run without the vaccum box up front, the avcv and the pcv. it was running before the engine swap with out the canister and all that, but now, i get only a start up and run with the choke on. it cuts off when i take the choke off. i only have one vac line going to fuel petcock. WHERE ELSE???
Old Jun 25, 2010 | 06:26 PM
justasquid's Avatar
Im not sure where else you need vaccum lines. I can't remember if that model had the vaccum lines going to the top of the carbs or not.
But, do you have the existing vaccum lines plugged? If you have open vaccum lines, the bike will run extremely rich and not run without the choke. Plug them with a bolt and tape em if you have open ones.
EDIT: I meant to say it will run extremely lean...
Old Jun 25, 2010 | 07:15 PM
elusions's Avatar
ok. i think they were plugged before with the broke engine but ill do the same here. think i still need one for the gas petcock.
M1ke
Oct 20, 2012 07:32 PM
EzElzz
Jun 24, 2012 02:09 PM
CaliKush
Apr 29, 2009 08:34 AM
aadoublea
Aug 18, 2008 10:16 PM
pinoyofmodesto
Aug 27, 2006 10:38 PM
