always on full choke and sometimes hard to start
Old Aug 24, 2006 | 01:18 AM
pinoyofmodesto's Avatar
Default always on full choke and sometimes hard to start
i have a 88 hurricane 600 whenever i can get it to start i always have to run it on full choke and i also sometimes have trouble starting it sometimes. i reall need help my clymer manual i think is pretty much useless. and i also have a high idle even when i use the idle adjuster.
Old Aug 24, 2006 | 11:37 AM
rrasco's Avatar
Default RE: always on full clutch and sometimes hard to start
what do you mean you have to run it on full clutch? like you need to readjust your clutch lever...or did you mean choke? may be a carb syncing problem or possibly carbs need a good scrubbin.
Old Aug 27, 2006 | 10:38 PM
Detroit Cane's Avatar
I hade the same problem with mine when I got it. Clean the carbs and choke and it should help out tremendously. I used a can of carb and choke cleaner from an auto parts store and it worked just fine.
hondalover68
Aug 26, 2011 02:03 PM
stevewaclo
F2 Tech
17
Jun 20, 2011 09:09 AM
Freewax
F2 Tech
Mar 5, 2011 09:37 PM
mbrown22
Nov 23, 2010 10:37 AM
JayBoCC2
Jun 23, 2009 10:23 PM
