91' cbr 600f2 - ran out of oil
Hi , first of all make sure you have petrol feeding the carbs, if your bike has been sitting for a period of time the filter could be clogged up, have a look in the tank to see if there's any debris in the bottom of the tank, setting up an auxiliary tank with a direct feed to the carbs is useful, they can be bought for cheap, good for synching the carbs, have a look at page 2-11 and make sure vacuum and vent tubes are not blocked
Hi , the two pipes your showing are the over flow/air vent pipes , there should be pipes connected to them and out to atmosphere, did you say you had petrol in the vacuum pipe,as that should be the fuel line to the carbs and the other two are the vent and drain pipes
A vacuum leak could also be causing havoc, or else maybe a bad spark like you say. Could even be bad gas. Happens a lot this time of year, especially with all the ethanol blends they jam down our throats these days
I know it's a new battery, but you still want to keep an eye on the voltage, especially if it's been cranking a lot
jayofnazareth
05-26-2011 12:08 PM
