89 cbr1000f-k
Old Oct 1, 2015 | 01:26 PM
walter warbler's Avatar
Default 89 cbr1000f-k
Hi,89 cbr1000f -k, no fuel getting to carbs,took the fuel tap out of tank,all cleaned up put back the way it came apart,rubbers all look good,when tip petrol down pipe engine runs ok and vacuum from pipe from carbs but still no petrol from on or reserve position,also if I suck the vacuum pipe no petrol comes out,am I missing something here or is tap knackered,
Old Oct 2, 2015 | 12:06 AM
Sebastionbear1's Avatar
Ummm, tap is knackered!
Was the bike running before? Wondering if someone else pulled the tap to bits and put it back together incorrectly??
I thought the Mk II bikes had a sealed fuel tap unit? 1989 should be a Mk II. There is a repair kit available for the MkII but you have to drill the rivets out to disassemble.
More info needed.
Cheers, SB
PS: Welcome to the CBR Forum!
Old Oct 2, 2015 | 01:07 AM
Smile
Thanks for reply SB,had nt been apart before,just left standing,thanks for info,looking into repair kit.
Old Oct 12, 2015 | 04:24 PM
groutby's Avatar
If there is a breather hole in the tank, could it be sealed/blocked causing a vacuum?..there is a fuel pump to consider also maybe?..tho doesn't seem to fit with your symptoms.
Cheers
Peter.
Old Oct 13, 2015 | 11:57 AM
Smile
Thanks for reply Groutby,all sorted now,bought a repair kit,when went to fit it,found hairline crack in diafram housing,so vacuum was drawing air and not operating diafram correctly,second hand tap off e bay,kit fitted,purring like a kitten again,cheers.
walivabuc
May 1, 2013 06:52 AM
Firefox11
Sep 19, 2011 01:58 PM
93CBR1KF
Nov 27, 2005 09:07 PM
93CBR1KF
Aug 10, 2005 11:37 PM
