CBR1000F slotted cam sprockets
Does anyone know where I might be able to find a set of adjustable (slotted) camshaft sprockets for the 1000F ?
I have an old article that showed Vance&Hines used to have them, but now they have gone cruiser crazy. Any help would be greatly appreciated.
I have been told by a mechanic not to worry about them. He said that #1 the CBR's don't have a lot of lift and #2 Honda gets its timing spot on so unless you are going for a full race system and have modified the capacity, flowed the head and/or changed the valve size you won't get much of a HP increase for all the rooting around you have to do.
One thing he said there are 2 things you can do to make the CBR faster.
1. Go Ohlins
2. Get some advanced rider training.
I've done the advanced rider training and its made me go a lot faster cheaper than forking out for go fast bits.
1. Go Ohlins
No bull , if that is what you want, I would go up a couple of teeth in the front sprocket. That will give her more "umph" at lower RPM's. That's a cheap fix.. it will effect your top end, but since you are concerned with low RPM riding, then that may suit you the best. Just an idea.
walivabuc
May 1, 2013 06:52 AM
