87 CBR600 Cam chain tensior
Old May 12, 2013 | 12:15 PM
V Saarela's Avatar
Default 87 CBR600 Cam chain tensior
Have not open yet and check, but...is it usual itīs enough to replace only the tensior, or is it usual also have to replace chain, slides or something else on this model?
Old May 13, 2013 | 03:47 AM
Fobwareagle's Avatar
Yes, if your bike is making the b.b.'s rattling in a can noise then just the tensioner gets replaced. You'll also need the gasket for it.
Old May 13, 2013 | 09:52 AM
V Saarela's Avatar
Thanks!
Only the tensior then.
Sorry, my English is not so good. What does "b.b.'s rattling" stands for?
Old May 13, 2013 | 10:35 AM
cc rider's Avatar
bbs are the little ***** that are used in air powered guns. if you shake them in a metal can it sounds like what you would hear if you have a bad tensioner
Old May 13, 2013 | 12:16 PM
V Saarela's Avatar
ahaaaa, of course ...and thanks!
Yes, I hear the bbs rattle, but only sometimes and mostly not when the engine is cold. I remember long time ago when I had an old CBR 1000F and it rattle first when it was cold. After a year it sounds also when the Engine was warm...ment it was a Little bit hurry to replace.
Well, I open just for the valves and was surprised, screws(yes, Iīve download the manual here, but not yet open it, I will). I suposed I will found shims because I was on this site(Wemoto where they have a notice on shim for this model) Honda CBR 600 FH 87 Parts at Wemoto - The UK's No.1 On-Line Motorcycle Parts Retailer
Iīll check the valves, maybe the rattle comes from the valves and then take of the tensior and try to check out it. If it not works as I want I replace it.
Many thanks for the help!
Old Jun 25, 2013 | 10:42 AM
V Saarela's Avatar
Well, I Clean and adjust the carbs
And adjust the valves
Especially the valves explained why the bike had some startingproblems
I also check the tensior, but what I found it worked well
So, now the CBR work well and starts good
jpopp88
Nov 14, 2022 12:34 PM
mcmahan87
Jun 5, 2013 05:13 PM
ROOKIE 09
Mar 25, 2011 07:26 PM
600f2supersport
Sep 10, 2007 11:13 AM
mindz
Jan 26, 2005 02:45 AM
