600rr won't start
Old Apr 13, 2014 | 08:59 PM
Ryanx251x's Avatar
Default 600rr won't start
I'm looking for any ideas and all help is appreciated. I have an 04 600rr. I pulled over tonight to get fuel. When I turned the back on after, all the lights were on like normal. I hit the starter button then everything died and now the lights won't come back on and the bike still won't start. The clock stays on until I put the key in the "on" position and the rpm needle will cycle when I turn the key back off. When I got the bike back home I checked the battery leads to make sure they weren't loose and the battery had a good voltage ruling out a bad battery, I think. My next idea is that the starter fuse might have blown but I'm not 100% sure. I also don't know if that would be in the fuse box or inline to the battery. Any and all suggestions are appreciated
Old Apr 13, 2014 | 10:35 PM
74demon's Avatar
Still sounds like a bad battery. Don't assume that its good just because the standing voltage is ok. What's the voltage with starter load on it?
Old Apr 13, 2014 | 10:59 PM
Ryanx251x's Avatar
I didn't get that far, I just hooked the multi up to the battery at sitting position and it was high 12.x. I didn't get any farther because I didn't want to spend the rest of the night in the garage. I'm hoping it's the battery over anything else, because that'd be an easy fix. But I had also been running the bike all day so shouldn't it have stayed charged? I've never had one just randomly die like that if so
Old Apr 13, 2014 | 11:19 PM
74demon's Avatar
They can just die.
Put your meter on it and watch the voltage when you try to crank it. If it goes much below 10v, battery is shot.
Old Apr 14, 2014 | 05:32 AM
Ryanx251x's Avatar
Thank you, ill give it a shot
The__Rider
Feb 19, 2010 12:57 PM
blaznone
Apr 15, 2009 09:11 PM
burtt9
Jan 13, 2009 02:13 PM
ebu3sg
Mar 27, 2008 02:15 PM
abcorona1
Jun 30, 2006 10:14 PM
