600rr rev down hangs but only at low rpm
Old Jun 6, 2018 | 10:25 PM
Tonyjardine's Avatar
Default 600rr rpm hangs but only at low rpm (video)
2005 600rr, 22k miles
This just started happening the last time I took it out, was always smooth revving down before.
I noticed it when pulling the clutch in at low speeds, but it also happens when the bike is simply revved past 5k or so RPM.
Lets say I rev it up to 8k rpm. When it revs down, the rpms drop smooth until ~3000 where it stays for a split second and slowly goes to idle.
Also it doesn't happen when the engine is cold, and gradually gets worse the hotter it gets.
I cleaned throttle bodies and cleaned/blew out the paper OEM filter as best I could, but it didn't help. Thinking it might be an air leak so I sprayed a bunch of carb cleaner all over the intake and such but it didn't effect anything. Maybe it's TPS?
Any suggestions would be really appreciated! I tried searching but couldn't find a solution.
Old Jun 8, 2018 | 09:29 PM
Default Solution
I turned down the idle screw just a tad and that ended up fixing the problem... never would've guessed it was that simple!
justinismach
Dec 1, 2016 08:27 PM
Paulalmighty
Feb 26, 2012 01:31 PM
prowheelie92
Jan 30, 2010 12:11 PM
