600F4/FX - Throttle cable
Can anyone help!!
After some advice about throttle cable! I've got a Honda CBR 600 F4/FX(2000) and looking to put everything at the carb end back to square one. Question is.... how much thread should show below the lower nut on the pull cable and on the return cable to get me there? Pictures would be great
HI, as regards the cables there's no real recommended positions, all the cables are the same size( for your bike) it's just a matter of set-up, once their connected to your throttle at the grip(adjusters slackened off ) then it will be easier to take off the carbs and fit them on, you can try in position but taking them off to do it is easier, then adjust play till you've got optimum position
