Advice wanted, Replacing Throttle Cable
Old Mar 16, 2006 | 04:39 PM
jbrooksF2SuperSport's Avatar
Default Advice wanted, Replacing Throttle Cable
Whats Up Fellas?
I was out dinkin around yesterday and snapped my throttle cable. Not a big problem, and i had planed to take off my plastics anyway for an oil change. However I have never switched out a throttle cable before on a modern bike. Furthermore when i ordered my new part the shop asked if i needed the push cable or the pull cable. I had no idea so i ordered the pull. So... yeah... any advice
live fast ride smart... and fast
Old Mar 16, 2006 | 11:46 PM
slowpoke's Avatar
Default RE: Advice wanted, Replacing Throttle Cable
The pull is usually the one that breaks. String the new cable in the same place and through the same holds as the old one. Then take out the old cable.
Old Mar 23, 2006 | 05:23 PM
well the replace went pretty smoothly.
1. plastics off
2. seat off
3. tank off
4. air box off
5. velocity stacks off
6. old cable off
7. new cable on at throttle grip first
8. this is key... down near the butterfly attachment to the carbs, there is a guide that you snap the cable into to ensure a tight fit and no loose slack. make sure you attach the cable to the butterfly first! then put the cable in to the guide you will not have enough slack to fit the cable to the butterfly if the cable is all ready in the guide.
but not a difficult project. i would say that with my local shop charging 63 dollars per hour I did myself a favor by earning one bleading knuckle and a lot of knowledge as to what is under the plastic.
thanks slowpoke
Old Mar 23, 2006 | 07:25 PM
shraz's Avatar
can you lube a throttle cable? because I want the throttle to snap back faster
Old Mar 28, 2006 | 04:22 PM
yes you can lube the cables. the most common lube is a squirt of WD 40 down the cable. but completely removing the cable holding it verticle and spraying lube down the cable till it comes out the other end would work the best. otherwise look for a stiffer throttle return spring.
cbr6rider
Apr 20, 2011 08:57 AM
acquarossa
Jan 8, 2011 02:12 AM
chestnut1011
Oct 13, 2008 09:24 PM
Rklamb16
Jun 20, 2008 01:07 PM
troyg3
Jun 18, 2007 11:16 AM
