2002 f4i Won't Start.... HELP!!!
Old May 7, 2007 | 11:32 PM
Soarer's Avatar
Default 2002 f4i Won't Start.... HELP!!!
I just went streetfighter with my '02 f4i. I plugged everything back in (all the connectors from the front end) and now I don't get a fuel pump priming buzz and the starter doesn't engage. I have the Bank Angle Sensor (tip sensor) jumped by connecting the two outer wires. Right now the headlights and marker lights aren't hooked up. The front wiring harness is just hanging there.
I've checked the fuses and they are all fine. The other curious thing is that I'm not getting any juice to the headlights. I've got juice going to the turn signals/marker lights but nothing to the headlights. Also, there is juice going to the Bank Angle Sensor. There is NO juice going to the fuel pump. My guess is that there is some safety feature that is preventing juice from going to the fuel pump but besides the neutral safety and sidestand and tip sensor, I don't know what else would prevent juice going to the fuel pump.
It's strange because the bike ran fine up until I pulled it apart. I have made sure it is in neutral, kickstand up/down, ignition on etc. The only other thing I did was replace the throttle cables which meant removing the tank and air box. I hooked everything back up though.
Any ideas?
Old May 8, 2007 | 12:42 AM
pawel's Avatar
Default RE: 2002 f4i Won't Start.... HELP!!!
I know that if you unplug the headlight the bike doesnt start, the fuel pump doesnt turn on. It is a safety featture in the headlight that if the bike is turned over it doesnt run.
Old May 8, 2007 | 01:07 AM
Soarer's Avatar
Thanks, I already jumped the tip over sensor. That is why the bike won't run if just unplug the main headlight harness.
Old May 8, 2007 | 01:13 PM
Soarer's Avatar
Come on, no one's got any ideas for me?????
thePUNISHER
Apr 22, 2017 08:32 AM
ChristopherXRD
Nov 14, 2013 08:28 PM
ahadeler
Oct 20, 2013 08:43 PM
sulavsingh
Nov 17, 2012 10:59 AM
Soarer
Jul 15, 2006 01:29 AM
