2002 f4i won't start
Old Oct 17, 2013 | 11:00 PM
ahadeler's Avatar
New Member
Question 2002 f4i won't start
I just recently purchased a 2002 f4i. I've been riding it as much as possible however last night I ran into some trouble with it. I was pulling into a parking spot and as soon as I turn the bars the bike shuts off on me. The tach is stuck at 1.5k rpm, the clock is not on. when I turn the key to on nothing happens. I checked the battery and it is good. any ideas what my problem may be? any pointers that any of you can give would be greatly appreciated
Old Oct 18, 2013 | 06:48 AM
RoadiJeff's Avatar
Senior Member & Lord of The Man Cave
Sounds like a blown fuse, possibly caused by a worn part of the wiring harness with a bare wire shorting out against the frame when the bars were turned.
Check every fuse, especially the main (30A?), replace any that are bad and turn the bars from side to side with the key on and see if it blows again.
Old Oct 18, 2013 | 07:44 AM
ahadeler's Avatar
New Member
Thanks so much! bike's starting again
Old Oct 20, 2013 | 01:22 PM
adapt63's Avatar
I had aftermarket indicators on a gsxr 600. Everytime i turned left it cut out. turns out the clown who fit them hadnt insulated the bare metal bits so they touched all the time. very annoying but a nice simple fix
Old Oct 20, 2013 | 08:43 PM
ahadeler's Avatar
New Member
You should see my rear blinkers hahah they're definitely the cause of the problem until I get an integrated tail light
thePUNISHER
Apr 22, 2017 08:32 AM
ChristopherXRD
Nov 14, 2013 08:28 PM
sulavsingh
Nov 17, 2012 10:59 AM
Soarer
May 8, 2007 01:13 PM
Soarer
Jul 15, 2006 01:29 AM
